vinny1575
Re: Manual Supports not working in 2.1
Ive tried that, its not working for me. :/
Edit: Looks like I was using "retinizer" which was causing it to stay in retina mode even with low res checked. I "de-retinized" the app check the setting you mentioned and its now working fine.
davedfx
barsam wrote:I've got a better solution for the moment. Until the support finds out an fix it... (within the next 6 months)
Left click on the Simplify3D application and choose Get Info.
There is a check box saying "Open in Low Resolution". Check this and you are done.
Thanks! This worked for me on Retina Macbook pro
jwiede
So having clearly established that Retina resolutions ARE the problem, has Simplify3D Support come up with an explanation why the problem didn't show up during their (allegedly) Retina-active testing?
joshuacarroll19
Yeah, I have a Macbook Pro Retina as well and I have the same exact problem. Hopefully this will be resolved in the next release...
Tedenda
I have a MBP 15" retina late 2013 and have the same problem.
