vinny1575
Re: Manual Supports not working in 2.1
Mon Apr 14, 2014 8:37 pm
Anybody else? Simplify3d developers?
barsam
Thu Apr 17, 2014 6:28 pm
Problem confirmed. I have the exact same issue.
I am suspecting it is the retina display giving the problem. Can someone confirm that?
The ones not having this issue, do you have a retina display mac?
vinny1575
Thu Apr 17, 2014 8:39 pm
Thank goodness. Ya I have a retina display as well.
Thu Apr 17, 2014 10:20 pm
well you might be onto something there because i do not have a retna and i dont have the issue
3Drasle
Fri Apr 18, 2014 2:52 am
Just tested. Works fine on PC win7-64 (no retina)
/Michael
/Michael, Denmark
barsam
Fri Apr 18, 2014 6:01 am
So let's try to keep this post on top until someone from the support team correct this HUGE bug.
If I am not mistaken 2.0 was not retina compatible, 2.1 is, so the problem was created due to this.
Paying a fair amount of money for a software is not only about getting something better from the open source and free ones, but at least you expect that the ones developing the software test the releases extensively under all platforms.
For me it is totally unacceptable to get a release that is not functional in so basic things like the manual support. This means that no one tested the software in a retina mac. So how is it possible to add support for something that it is not tested at all?
And the release is not even beta, it's an official one. So no excuse there for this bug.
vinny1575
Fri Apr 18, 2014 6:51 am
I did email support and they said they are not having a problem with their macs. They said they are the very same setup as well. So idk whats going on. I'm just glad Im not the only one because that would mean it would never get fixed.
vinny1575
Fri Apr 18, 2014 8:05 am
Temp fix. Use an app like the attached to change the resolution manually. try 2880 x 1800. After that open simplify3d and the supports should work.
Obviously not ideal, but it works.
Change Resolution.app.zip
(367.26 KiB) Downloaded 127 times
barsam
Fri Apr 18, 2014 12:37 pm
Thanks for the application.
I played a little bit with it, and I confirmed that the problem is the retina resolution.
This application what it does is cancel the retina resolution, so what ever resolution you select, (even the default at the time the application opens) and press ok, then the retina resolution is canceled and the manual support is working.
And as far as the support is concerned and your mail, they don't have a retina mac display. And even if they have, it is not activated.
100% confirmed retina resolution problem....
barsam
Fri Apr 18, 2014 12:54 pm
I've got a better solution for the moment. Until the support finds out an fix it... (within the next 6 months)
Left click on the Simplify3D application and choose Get Info.
There is a check box saying "Open in Low Resolution". Check this and you are done.
