shasselberg
Prime Tower, Ooze Shield and First Layer Setting
Mon Nov 13, 2017 9:17 am
Prime towers and ooze shields don't stick, but the print itself does. Are we certain that they use the same first-layer settings as the model? If I print the first layer at a higher thickness, does the prime tower and ooze shield use that setting?
brian442
Re: Prime Tower, Ooze Shield and First Layer Setting
Tue Nov 14, 2017 11:00 am
Yes, they do. You can check the gcode to easily verify this yourself too ;)
shasselberg
Tue Nov 14, 2017 11:06 am
Thanks.
So, then, why don't they stick when the rest of the print does? Watching the beginning it seems to have insufficient flow, when the rest of the print is fine.
