Prime Tower, Ooze Shield and First Layer Setting
Posted: Mon Nov 13, 2017 9:17 am
by shasselberg
Prime towers and ooze shields don't stick, but the print itself does. Are we certain that they use the same first-layer settings as the model? If I print the first layer at a higher thickness, does the prime tower and ooze shield use that setting?
Re: Prime Tower, Ooze Shield and First Layer Setting
Posted: Tue Nov 14, 2017 11:00 am
by brian442
Yes, they do. You can check the gcode to easily verify this yourself too
Posted: Tue Nov 14, 2017 11:06 am
by shasselberg
Thanks.
So, then, why don't they stick when the rest of the print does? Watching the beginning it seems to have insufficient flow, when the rest of the print is fine.
Posted: Wed May 27, 2020 11:23 am
by Predaxis
I see this is VERY old, but I am having the exact same symptom. Was anything ever found around this?
