Can’t slice tall objects
Posted: Thu Nov 30, 2017 2:47 am
by Jermboy416
Hello,
I have a 4’ tall delta machine and I’m trying to slice a tall object. In the preview screen once the object passes about 300 mm it is cut off. Even when I slice it it’s as if the model just ends right there.
Can simplify3d not handle objects taller than 300 mm?
Re: Can’t slice tall objects
Posted: Thu Nov 30, 2017 9:22 am
by brian442
I slice parts taller than that all the time. Are you sure you don't have the "stop printing at height" option enabled on the Advanced tab? Is your build volume in S3D taller than 300mm?
