Hi all,
I searched on here and found a couple posts but most lead back to previous version of the software prior to 4.0. My issue/ question is this , currently I am using the cr10 profile modified slightly, mostly print speed, infill, and brim, and or raft settings. I've been trying to print without a raft recently and just us a brim. However I've notice that even with a first layer height of 90 or even 80 % my skirt / brim will never stick. Even at 30mm/s on blue tape ( which I use with no issues ever). The weird thing though is if I use a raft and default the skirt / brim to be offset from the piece like it is by default the skirt will print totally fine. I've read that there is a speed difference with brim vs raft, which is visible in the program. But am I missing something as to why my brim looks way thinner and just will not adhere, yet if raft is enabled and reset to the 4mm offset it functions totally fine?
