not much data about crash available
Unable to recover from a kernel exception. The application must close.
Error code: 3 (subcode 2)
(pid=12212 tid=18288 simplify3d.exe 64bit)
Visit http://www.nvidia.com/page/support.html for more information.
Faulting application name: Simplify3D.exe, version: 4.0.1.0, time stamp: 0x5a2fe51a
Faulting module name: nvoglv64.DLL, version: 23.21.13.8871, time stamp: 0x5a344821
Exception code: 0x40000015
Fault offset: 0x00000000010420cf
Faulting process id: 0x2fb4
Faulting application start time: 0x01d384a1f71ba7b8
Faulting application path: C:\Program Files\Simplify3D-4.0.1\Simplify3D.exe
Faulting module path: C:\Windows\system32\nvoglv64.DLL
Report Id: 50143efa-f09c-11e7-acc9-74d02bc82ac6
Fault bucket 1352327495, type 410395426
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: Simplify3D.exe
P2: 4.0.1.0
P3: 5a2fe51a
P4: nvoglv64.DLL
P5: 23.21.13.8871
P6: 5a344821
P7: 40000015
P8: 00000000010420cf
P9:
P10:
H:\temp\WERC7A2.tmp.WERInternalMetadata.xml
These files may be available here:
e:\Users\arhimed\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_Simplify3D.exe_409b355a1f2c2b9c35275697f480181bf6cab85_6361f508
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
The description for Event ID 13 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video7
Variable String too Large
the message resource is present but the message is not found in the string/message table
\Device\Video7
NVRM: Graphics TEX Exception on (GPC 3, TPC 4): TEX NACK / Page Fault
