Just got S3D, i had been using Cura. In cura, at even faster speeds, my calibration cubes has smooth sides, now using S3D, i'm having regular lines on the sides of the print. The normal advice is that this is an extrusion issue of some kind. What gives??
I am using the measured filament width, (1.72mm) i had on the old software. The Extrusion multiplier had been 0.9, I changed it to 1.0, but it had little if any effect.
What's going wrong?
The green cube on the left was from a few days ago, same brand of filament, but using cura.
The white cube on the right is what i'm getting now, using s3d...
