With an SD Card inserted I get the following when I click on
Print from SD Card:
Attempting connection at /dev/cu.usbmodemFA141...
Testing plaintext communication protocol...
Connected to machine!
SENT: d501015e
WARNING: packet transmission failed, retrying... (d501015e)
SENT: d501015e
READ: d50181d2d50181d2
SENT: d503002800b7
Firmware version 0 detected
SENT: d50115a2
If I remove the SD Card I see the following when I click on
Print from SD Card:
I have reformatted the SD card and ensured there are only a few files on it (I thought I might have hit a file number limit).
