boovya
high settings/bad or no print. medium settings near perfect
Tue Mar 06, 2018 9:46 pm
I’m just printing a 20x20 calibration cube to setup my filaments material settings. I’m using medium quality and about 2000 mm/s and it works nicely. When I go to test out high setting the first two layers barely extrude.
Stupid question but if I change my layer height do I need to reset my nozzle offset?
I’m using a da Vinci pro
Re: high settings/bad or no print. medium settings near perfect
Wed Mar 07, 2018 4:05 am
Simple answer.....No.
But there's probably a more complicated answer needed....but you need to say what the issue is first!
boovya
Wed Mar 07, 2018 5:12 am
When I print at high settings it doesn’t extrude filament. Meaning when I changed over the settings you normally get your skirt outline and raft or first layer starts printing...mine doesn’t extrude anything at all or it will eventually print some residual mess around second layer and is usually inconsistent. Thanks for the help
