boovya
Thin walls not extruding correctly
Tue Mar 06, 2018 9:53 pm
Trying to print a low poly ring off thingiverse. Even at medium settings, low speed 100% infill I cant get away from these gaps in the Wall. Never saw this before any ideas?
Re: Thin walls not extruding correctly
Wed Mar 07, 2018 4:03 am
You probably need to tweak settings a little. Best to attach a factory file to a post.....File menu....Save Factory File......and then someone will be able to review your settings ....and hopefully advise exactly what changes to make.
boovya
Wed Mar 07, 2018 5:46 am
here is my factory file thanks!
edit: sorry the only thing different should be i tried infill at 100% and that didnt help either
lowpolyring.factory
(8.39 KiB) Downloaded 65 times
