I can confirm that version 3.X.X does not have this issue. 4.X.X does it does not print the supports in the middle of the stl until layer 35 which is 4mm off the bed. Supports printer closer to the outer edge of the object print fine.
Flip the STL so the domed part is facing up, and generate supports for it. check the print preview and you will see supports are generated where they should be but they are 4mm too high in the center circular section and cause printing spaghetti in mid air
