Fabrikator 2 mini not connecting
Posted: Fri Mar 16, 2018 10:38 am
by iHover
My Fabrikator 2 mini wont connect. I see its com port (3) but the software wont connect. If I try opening it in repeater it connects just fine. Is there some thig other than Machine control panel for setting this up that Ive missed?
Re: Fabrikator 2 mini not connecting
Posted: Sat Mar 17, 2018 10:33 pm
by iHover
Update: unchecking wait or startup will allow the Fabrikator 2 mini to connect but it still wont work with the software. If I go to move the print head or bed it will only execute one command and then wont do anything.
Posted: Fri Jan 04, 2019 11:47 pm
by tenaja
Did you ever get it to work? I got one, and it s3d won't work with it, but repetier works fine.
I'd appreciate suggestions.
Posted: Thu Jan 10, 2019 1:18 pm
by S3D-Jake
Are you both unchecking wait for start up? Do you see anything at all in the Tools > Machine Control Panel > Communication log?
Common solutions for connecting and printing from USB can be found at our FAQ.
https://www.simplify3d.com/support/faq/#faq-4630
