Page 1 of 2
Simplify3D.exe - Application Error
Posted: Sun Mar 25, 2018 4:09 pm
by ljack
S3D refuses to start. Used to work last time i tried a week ago. Not it fails.
"Simplify3D.exe - Application Error
The instruction at 0x00007FF71EACB2D referenced memory at 0x000002272A7AD380. The memory could not be written.
Click OK to terminate..
Click CANCEL to debug...
Re: Simplify3D.exe - Application Error
Posted: Mon Mar 26, 2018 6:01 am
by rrdavis
A quick search yields many ideas about this issue.
https://www.google.com/search?q=the+ins ... be+written
Sounds like it is usually due to another background application interfering with the program (perhaps an anti-virus software or some other theming/skinning program?)
Posted: Mon Apr 02, 2018 10:56 pm
by GavinBro24
Hello,
The same issue popped up for me out of the blue and I have yet to find a solution. Have you found anything new since your post?
I’ve found out it has to be something on my computer not allowing it but I’ve tried reinstalling Simplify3D and I’ve also removed softwares I had installed at a similar time the issue started happening. But I haven’t had any luck.
-Gavin
Posted: Tue Apr 03, 2018 8:43 am
by rrdavis
Maybe it is a problem with a recent Windows update. Might help to know what exact version and build number of windows you are using.
Press Windows+R, type "winver" into the run dialog, then press enter. Then either post that screenshot or copy the exact OS and build number and post it here.
Posted: Wed Apr 04, 2018 3:05 pm
by GavinBro24
Here is a picture of my version of windows. I feel like when the problem started happening, I vaguely remember updating.
Posted: Thu Apr 12, 2018 12:19 am
by GavinBro24
I posted the screenshot of my windows version. Does this help?
Posted: Fri Jul 20, 2018 2:04 pm
by johnnyo1012
Has this been solved? I have the same issue right now...
Posted: Thu Sep 13, 2018 3:36 pm
by Skeksis
This just started happening to me as well. The only thing I can think of is that I had the WIndows 10 program called 3D Builder running at the time I tried starting up Simplify3D and ever since it will not start now. Ive uninstalled and reinstalled the program but still fails.
Posted: Thu Jan 10, 2019 10:47 am
by spottyshowers
Just started happening to me today.
I noticed before i shut down the PC yesterday that Windows 10 was going to start the install of an update (January 8, 2019—KB4480966)
Since this morning i cannot use S3D. All that pops up is Application error.
Any workarounds?? I don't want to uninstall in case i lose my profiles.
Posted: Thu Jan 10, 2019 5:27 pm
by S3D-Jake
Please try deleting the savedState.factory file located in the directory specified in this FAQ entry.
Please let me know if this allows you to use the software again.
