Not to add more fuel to the fire, but I design many functional parts (brackets, adapters) for use in automotive projects, where final dimensions and overall model strength are required. I use Catia V5 to design parts, then export them to .stl.
I've noticed an issue that I think is related to this threads subject with my prints. My example is with a single perimeter gap between
thin walls, where the wall thickness total is less than the wall perimeters setting.
My printer has a 0.4mm nozzle (I've tried auto extrusion width as well as force overriding to 0.4 and 0.38). One would think that as long as my wall thickness is a multiplier of 0.4mm I should always have a solid
thin wall as long as it's thinner than the perimeters setting.
Pictured below; setting is for 5 perimeters, so in theory any wall less than 4mm thick should be solid. The wall below is 2.8mm thick, so that should be 7 perimeters. The behavior however is to print 3 perimeters through that section of the model on each wall and then leaving the center not printed/a gap,
even if I use 100% infill.
I haven't found a setting that fixes this yet, other than using Cura (which, I spend $$$.$$ on S3D so why would I want to do that?). It's rather annoying for really
thin walls, like 1.2mm, where they print as two 0.4mm walls with a 0.4mm gap between them. Right now the only way I can get a clean print on
thin walls is to orient them such that they are printed in Z, not X and Y as in the picture above. I should note that this gap doesn't happen on the top/bottom layers, it only exists inside the shell.
