EdoHamburg wrote:Fixed in v4? Does anyone knowes?
IMO it looks identical as 3.1.1. it will create solid
layer under all but innermost perimeter, so if you have the usual 3 perimeter's it will go under outer and middle perimeter only.
Not too bad but far from very strong.
If you go with 5 perimeters it's much better as it will go with outer 4 (only innermost one is not on
top of solid)... much better, still not as strong as it could be.
so workaround is to use more perimeters as it goes under all but the innermost one (3.0.0 was iirc going only under outermost one, or not even under that one but touching it on the outside so that was a big change in 3.x.x when it came in) .. I, whenever I can, add a small fillet or chamfer as that often helps
