About a month ago I elected to go to a wireless printing setup because of this issue. I don't know if there is a fix for it yet or not. I did not want to lose the power of S3D (I'm hooked on it). The solution I implemented uses a Raspberry Pi 3 following the directions in the link below. For about $60 worth of parts all from SparkFun.com, the Pi 3 replaces my laptop and I still get to use all the power of S3D. You just set up the models in S3D, create a gcode file, and transmit the file to the Pi 3 connected to the printer's USB using OctoPrint. I'm now hooked on this too! All required software links are in the short directions at the link below. Project took less than a couple hours. Thingiverse.com has an STL to print a case for the Pi 3.
Pi directions:
http://3dprintingindustry.com/news/week ... ess-78383/
Pi case:
http://www.thingiverse.com/thing:922740
