Martin Majewski wrote:I totally support this! I want to have an option like "Send gcode to Octoprint" besides the "Save toolpath to disk" and "Beginn printing over USB".
As I am using my Macbook Pro with S3D it is not convenient to print over USB for hours.
It is also no option for me to use a SD card, because OctoPrint offers so much more control then my printer's LCD controller.
Saving the gcode to disk just to upload it manually into OctoPrint is sooo tedious.
You get nearly the same functionality already if you take the time to setup the watch folder as a network shared folder.
from the Octoprint Config
http://docs.octoprint.org/en/master/con ... tml#folder :
# Absolute path to a folder being watched for new files which then get automatically
# added to OctoPrint (and deleted from that folder). Can e.g. be used to define a folder which
# can then be mounted from remote machines and used as local folder for quickly adding downloaded
# and/or sliced objects to print in the future.
watched: /path/to/watched/folder
Mount the folder on your mac, save the gcode there, and then it's in your Octoprint queue.
