I like to save factory files pretty often when tinkering, that has saved me in instances where my computer crashes. Most times, I find I don't need to save factory files since I'll be working with one part/one process. However, when multiple parts are orientated with multiple processes, I definitely like to save factory files to log my process!StealthMicro wrote:I do quite a bit of work in Simplify3D and one annoyance I have is it seems to save only when you close the program using close. I find a lot of times I will open the program and it will have a pretty old workspace. I can of course remove the stuff from my workspace but I loose things too. Like if I create a new Process and don't specifically close the program and go back in for instance a power failure, stuck com pot (also happens quite a bit). If it could simply auto save even once every 30 minutes but like 10 minutes would be more beneficial.
