BaudR8 wrote:AndersE wrote:Hmm, so s3d does not support smoothie correctly?
Shame, as i am about to buy a smoothie board soon..
According to Leon, it seems like the Smoothieboard/Smoothieware is supported, he just had his smoothieboard configured incorrectly. If he had used any other slicing software he would have run into the same exact incorrect configuration issue
In my defense, it's the smoothie default config that operates different from every slicer out there for dual extrusion...
When I originally posted this here, I was under two misconceptions.
1. That T# was not supported at the end of a line. In fact I was specifically told that Smoothie would not support this because it is improper gcode grammar. It was later revealed that someone has put in a hack to take the T# and execute it as a separate command.
2. The M code for setting the second extruder temperature is different for extruder 2 and I thought this was a requirement. Fortunately, it behaves fine if you just change it to the standard 104/109 in the config file.
Overall, I'm quite pleased with smoothie and would recommend it *if* you're a power user that is OK with a system that's still very new and under heavy development.
