Very impressed with this software! I found a couple of bugs that I think are easy fixes.
-Red Extruder On Light on the "Machine Control Panel" Stays on after a USB print job. This might be my machine not communicating properly after a print, but it should be a pretty easy thing to test out.
-Tab order is off on the "Machine Control Panel." After changing the Extruder temp the Tab key selects the Heated Bed "Set" button and after changing the Heated Bed temp the Tab key selects the Extruder "Off" button. I think it would be much more useful after changing the temperature for the Tab key to select the "Set" button of the respective heating element so all you need to do is hit the space bar and the temperature is set!
Thanks!
Brad
