I have a Powerspec 3d pro and when I try to jog the machine while set to the left extruder via simplify 3d it jogs on the wrong axis. When set to use the right side it works fine. All moves go the right direction on the right axis. I even tried the flashforge creator pro profile which is basically the same machine.
My mightyboard says FF rev E which I assume means Flash Forge. I am using the stock firmware which is a customized for powerspec sailfish 7.7. I would like to flash it with stright up sailfish 7.7 but i am not sure what firmware to use. Maybe this is the problem.
Any Ideas?
Thanks in advance
