Zirngibism
Top layer not printing correctly
Printer: Ultimaker 2
Material: Ultimaker Blue PLA (came with printer)
I am new to Simplify3D and 3D printing in general, and am running into a big issue with printing this model from Simplify. The models start out looking like a clean print, but the top layer gets ruined every time. It looks unfinished, like it's some kind of filler layer. (I don't know how the underlying layers printed but they seem pretty good in comparison.)
The reason I think this is a Simplify3D issue is because the model prints fine from Cura!
I have tried this with default settings (by selecting a different printer then returning to the Ultimaker 2, quality set to high), with no luck.
Here is the factory file for anyone who cares to check it out:
https://www.dropbox.com/s/s1k5wffxkhomj ... ctory?dl=0
I thought maybe the "layer" setting would hold a key to this. Here is what I had:
http://i.imgur.com/JT00exQ.png
The preview model looks... odd. Like it's not filled all the way.
http://i.imgur.com/ItmBEYx.png
http://i.imgur.com/OVTWLa2.png
Screenshot of model:
http://i.imgur.com/cBhwTDY.png
Help much appreciated! Thanks.
KeyboardWarrior
Re: Top layer not printing correctly
Zirngibism wrote:Hi,
The attachment SimplifyPrints_1.jpg is no longer available
The attachment SimplifyVsCura.jpg is no longer available
Using the FFF file attached, I got the following print on an UM 2 using PLA. To import this FFF file, you would just go to the process settings and click Import and then import this file. **Also, make sure to switch to the PLA-Preconfigure**
Screen Shot 2015-05-11 at 1.15.55 PM.png (113.11 KiB) Viewed 1770 times
Ultimaker 2_revised.fff
(8.89 KiB) Downloaded 196 times
