When printing multiple parts in a single print sometimes a piece will get knocked over. The printer will keep trying to print on top of where it was which can cause a lot of build up and in most cases causing a chain reaction knocking over many move pieces. Typically for me the nozzle will just take the mid-air noodles and drag them all around and it will slowly build up into a blob on the hot end itself which is not good... This mostly happens half way through a tall print and its a waste to restart, especially if you have lots of other pieces half done on the same platform.
Only solution right now to a part falling over mid-print is babysitting it the rest of the way cleaning the noodle mess from the missing piece, or restarting the print. I find simplify3d's "start at height" feature really hard to use. It will either start a layer too high, or start into the last layer causing more problems trying to print directly into the last layer.
Some way to be able to select the part from the printing preview screen and tell the printer to skip this piece for the rest of the print without interrupting the print. Maybe like a "ignore" button, and you drag-select the gcode preview, this wouldn't work if you do a SD card print, but from the computer printing it should be able to simply change the gcode on the fly, maybe it pauses the print temporarily while it re-calculates the new gcode. Any input on this?
