I use some time Simplify and with this time is more and more experience.
So I am working now to obtain very smooth surfaces at PLA and ABS almost exclusively with Layer heights below 0.1mm.
So I have a NEO of German RepRap is not intended for such a thing. This I have a little overworked and especially the pressure bed stiffened and so can now layer heights up under 0.02mm Print and with still good print times.
Here I have a chinese lion in the pressure of PLA and a layer height of 0.03 mm at 70 mm / s and a 0.5mm nozzle
Or what I have also printed the dolphin by Don Foley.
Layer height 0.02mm at also 70mm / s and a 0.5mm nozzle
For dolphin I also have a platform gestalltet represents the surface of water and I represent the Dolphin in jump. By the fine print, it is particularly easy even to paint it so that you can not recognize that it was printed.
I'm still learning and still do not see the end of the options when departing every now and then from the usual ways of thinking.
Greetings Edwin
