Uthayne
Strange Gaps in Preview Mode
Been running into an issue occasionally where the preview mode will show these gaps in certain areas of the model (see attached).
Strangely enough, I can sometimes manage to correct it by re-slicing the model. I haven't tried printing when the gaps are shown, as it does skip over those parts when I slide through the layers in the preview mode.
Has anyone else ran into this problem?
Re: Strange Gaps in Preview Mode
Post the factory file. This is usually because of mesh issues.
iPa64
use repair menu to check if there some manifold edges,probably there is .
Uthayne
Turns out there were some problems with the mesh that were fixed when I ran the STL through netfabb. A little confusing how it would only fail sometimes though...
Slices without a problem now!
Successful Print
Successful Print
Bolt.factory
Original (flawed) factory file
(338.22 KiB) Downloaded 161 times
