Hello all.
I recently moved to Simplify and I was wondering if there is a button or command that will place components on the print bed. What I mean by this is that when I load a new part it often needs to be rotated so that a flat area of the print is on the print bed. When I do the rotation, example: half sphere, I than have to manually shift the object up or down so that it mates with the bed. In Cura there is a lay flat button or when you rotate the object it plops the part onto the print bed without vertical adjustments.
How do I go about doing this here.
