jb999
Crashes trying to read any .stl
Just got my creator software and wanted to try it out.
The program crashes trying to import several stl i have pulled from thingiverse. (I haven't tried stl files from elsewhere).
First time I tried to load an item i was able to load and view http://www.thingiverse.com/thing:42638 on the table but then quit the program. Since then, it crashes on other things I have tried to load.
I thought this would be small (in case it was a memory issue)
http://www.thingiverse.com/thing:15151
but crashes on import also
MacBook Air 4GB OSX 10.7.5
I pulled all peripherals and did a reboot and see the same thing. Ran uninstaller...ran installer...same thing, import causes crash.
It looks like the file is being loaded...it takes a second, and the loading bar proceeds across the window.
jb999
Re: Crashes trying to read any .stl
Installed onto my Mac Pro running 10.8 and it ran, so I upgraded the air to Mountain lion and now it is running
