I think I figured out why you didn't get notified! When you are creating your Forum post, you need to place a checkmark in the box labeled "Notify Me when a Reply is Posted". Options are located under the green Preview/Submit buttons.magicwiser wrote:Sorry for the delay but I assumed that the fourm would email me if anyone responded. Anyway, here is the factory file. Set support for a 35 degree angle.
Ahh thanks for the advice. Since printing that top I have had similar problems with other rounded objects but now that I think about it, they are all pretty small. The few larger objects I have printed have all come out just fine. I’ll have to make that change and try reprinting. I’ll let you know tomorrow how it turns out.tri-lite wrote:I love working with supports so I was glad you posted your Factory File. I believe the problem can be seen by rotating your model in Preview Mode to see the underside of the model construction.
In the images attached, you'll see that with 4mm supports, there are no supports placed under the very center of your model. But if you change the support resolution to 2 mm, you'll see that a network of 4 supports are placed in the very center of your model. I didn't print your model, but I believe this center support structure will be vital to the construction of your model if you print it in this orientation.
Here's a rule of thumb: The smaller your model (like your thumb-sized model), the smaller your support resolution should be.
Hi Magicwiser,magicwiser wrote:So I reprinted the top using a smaller support resolution (1 mm) and it definitely improved the quality of the print. As you can see, the basic shape is perfect. However, the bottom of it just doesn't look very nice. At the end of the day I can live with these results but it would be nice to be able to print perfect objects. I was wondering if using a slower print speed would fix this?
I have attached the updated factory file as well.
