Hello,
I am trying it on a trio too. The gcode output file from Simplify3D, still needs some tweaking. I am trying to figure things out, comparing it to the gcode from the cubeX software.
Here is a way to read the gcode from the CubeX. The .cubeX file is encoded so it cannot be read, but:
The CubeX 1.07 software (not current 1.08 version) creates by accident an unencrypted .bfb file (readable in notepad) in the same folder it puts the CubeX build file. So you can look at the CubeX code file and compare.
Here is a link to download the CubeX 1.07 software. (anybody can install it since it does not have software key)
https://docs.google.com/file/d/0B1EQlD5 ... dmVWs/edit
Note: If you get a message "you do not have privileges to install etc....." during the install, try the install again by right clicking on the setup.exe file and select "Run as administrator".
I am looking forward to do some prints with the Simplify3D software, that should be great. I like a the tweaking options and the support features.
So hopefully we can figure it out soon.
