zaus1978
XYZprinting Da Vinci 1.0 AiO starting print early
I have a Da Vinci 1.0 AiO i am trying to use non xyz filament with it i have a filament reseter but because of my firmware i cant set custom temps for the bed and exturder. The print always starts at 213 for the extrude and 90 for the bed when i need 220 and 110 once the gcode is running it dose get up to the right temp but the first layer is not sticking. Is thier a way to use a start script to have the printer pause for a few minutes until the temp get right. Or some way to override the commands coming from the firmware
BaudR8
Re: XYZprinting Da Vinci 1.0 AiO starting print early
the da vinci printers have their own little startup routine built into their firmware, which includes preheating the extruder and bed to the temperature stored in the filament cartridge. You may be able to add something like G1 Z0 and then G1 Z150 and then another G1 Z0 to buy yourself some time for the printer to reach the temperature you want it to get to before printing
scobo
There is an option in the temperature tab to wait for the temperatures to stabilize.
Make sure it's checked and it'll cause your printer to wait till it reaches the required temps before starting the print.
Elegoo Neptune 4
Slicers - Simplify3d, Cura
3D modelling - 123D Design, Mesh Mixer
3d scanners - Rivopoint Mini and Pop 2
wetsparks
Are you changing the bed settings in the FFF processes settings?
I have a Dav 1 running J firmware and have no problems with temperatures. I set the bed to 95 for the first layer and then 90 for the rest of the print, works perfect. Ohh I'm running the head at 235 for the first layer and 230 for the rest using filament from an independent company :D
