Plunket
Modifying generation gcodes
I want to change the way the gcode is generated:
G90
M82
M106 S0
M140 S0
M104 S210 T0
M109 S210 T0
I want to add instructions between this code.
I do not want to modify the Gcode manually, I wonder if I can change the way that Simplify3D generates the Gcode.
Thanks
BaudR8
Re: Modifying generation gcodes
You can edit the starting G-Code in the Scripts tab.
;replace with your custom gcode
M140 S[bed0_temperature]
M190 S[bed0_temperature]
M104 S[extruder0_temperature] T0
M109 S[extruder0_temperature] T0
G28; home all axes
This should do whatever gcode operations you wish prior to preheating, by having the variables bed0 and extruder0 in your starting G-Code, I believe s3d is smart enough to not put it in automatically since it knows you're doing it.
