Rebekah_harper wrote:hiya,
if you go to file in the menu. you can save factory files. basically you can say they are raw data files which save your setup and part before it is sliced.
allows you to stop save and go back to it to edit or if you are using a different material to make changes to temp and extruder behaviour etc...
the layer you are referring to is difficult to get perfect. I tend to use a high % density with a 0.1 separation.
I have to admit you have done very well with that result so any better will require some sand paper.
so I don't see a need for a factory file to be honest. but they are very handy to save none the less. I save a factory file, G-Code file and X3G file (something my printer uses) so that I have at least a record of my work in all formats.
do a search for 'TIP OF THE DAY' one of the guys on here put a lot of work into explaining every feature. exceptionally useful.
Thanks a bunch! Maybe I will still post the file to see if you guys see any contradicting settings or anything.
