Any advice? Factory file attached.
Layer Height: .1mm
Solid Top/Bottom Layers: 4
Perimeter: 2
Fill: 100%
Do you generally run all your models through that service before printing or wait until you see a problem first? Have you ever had it "fix" something that actually *created* a problem that didn't previously exist?DarthRevan wrote:I typically recommend and use https://modelrepair.azurewebsites.net/
I generally use that site when I can't otherwise explain why something is happening. If the issue can't be linked to my settings, or my machine, then it's typically the model.dvation wrote:Do you generally run all your models through that service before printing or wait until you see a problem first? Have you ever had it "fix" something that actually *created* a problem that didn't previously exist?DarthRevan wrote:I typically recommend and use https://modelrepair.azurewebsites.net/
