Hi All,
I've tried using Vase mode for the first time last night and the end result did not reproduce the model with the correct wall thickness.
The actual wall thickness is 3mm but the printer produced a single extrusion width wall in my case that is from a 0.35mm nozzle on my Leapfrog Create HS.
Has anyone had this problem and how did you solve it? I am sure I cannot be the first person to have this problem.
Apologies if the answer has been posted elsewhere however a search for the issue per the subject line did not yield any results that could help.
Appreciate any help and thanks in advance for any suggestions.
Kind regards
Dave
