efes
pink woman problem :(
hello
This is the second time the problem?
an idea please?
thank you
Re: pink woman problem :(
Looks like you need to increase your Outline Overlap percentage by 5-10% (see Infill tab). I would also suggest increasing your Infill Extrusion Width by 50%, but when you do this, be sure to also double your infill percentage to maintain the same fill.
Finally, as another options, many people have printed beautiful versions of that model using vase mode. So you may also want to try that since it seems like it would work for this part. Read more here: viewtopic.php?f=8&t=1999
efes
Hello B)
I am stubborn! I soon succeed! :silly:
my test today :
no problem with my printer, no stop or bug.
Build time: 3 hours 40 minutes
I joined the FFF
mode vase print
some small defect above to incorrect configuration s3d :(
efes
continue ....
womanbody.fff
(9.33 KiB) Downloaded 353 times
efes
configure how to fill in the red frames?
you need more perimeters or more infill to support the perimeters that you have. lowering the layer height will help as well
efes
jimc wrote:you need more perimeters or more infill to support the perimeters that you have. lowering the layer height will help as well
I tried some support,infilI.... i have failed :(
tri-lite
You might already know this tip. When you have a problem at the top of the model, don't waste time printing the whole model. Instead, drop the model below the build plate and just print the top portion as a test. Then you can try several solutions without wasting a lot of filament.
With the new models window, it's very easy to manipulate the model quickly.
what % was the infill? thats a smaller print and the feature will need good support to no get gaps right there. 30-35% would be good. lowering the layer height as well will make the steps each extrusion has to move over smaller.
efes
no infill
print mode vase !
