PV_Eng wrote:Hello,
I need your help again ! The printer works fine with the current parameters but there is a little problem with the last perimeter extruded. As you can see on the following picture, the last perimeter quality is bad compare to the first (the outside perimeter is the first printed and the inside one the last printed). Do you know where this issue comes from?
Thanks for your answers!
In general that looks like a problem where the extruder is too close to the plate, why it's only happening on the last inner fill seems very odd to me. Did you change any of the heights? I really don't know why this would cause only the inner right to be flat though. Is it more like only the inner ring on the first layer is like that? And the second layer is correct?
