fantome wrote:I've used concentric infil and it does go round and round if the object is round. The extruder follows the outline of the object.
I set the infill to 100 % though. It doesn't just do the top layers, it does every layer if the infill is set to 100%.
This is the same setting that we use to print circular gaskets with NinjaFlex and it works the best. We do use sometimes rectaliniar infill less than 100% when we have to, but the best results are always when the extruders does not has to stop at any moment and just keeps moving until the print is finished as far as possible.
With that and with all speeds at 100% and very few retraction we get some very good results with NinjaFlex.
