fns720 wrote:dsegel wrote:What happens if you do a skirt instead of a brim? Try setting the offset to 5mm.
Also post a FF so we can see if it's your settings somewhere else.
Skirt is the same - S3D does not generate it. How can I export a process definition? There was an export button in 2.2.2 but now only a "Save as new" button exists and I do not know where it saved my settings.
Finally I found it - I left "start printing at height" switch ON and its value at 0.2 mm (with 0.2 mm layer height so that's why it skipped the entire first layer)
I tried it in v2.2.2 and it generated the brim even if I turned this switch ON.
On the other hand please explain how can I export a FF.
