jheikkila54
Printing with different nozzle sizes
Hey Guys,
I have been using Simplify3D for about a week now and love it, especially 3.0 over 2.2.2. I would like to speed up my print times however using different nozzle sizes. I have read other posts from various forums and appears that it is a fairly common topic. What I would like to know is if I use a .2 nozzle for finer detail on the perimeters and a .8 nozzle for infill, will I not be able to print .05 or even .1 layer heights anymore? Is there a way to setup Simplify to print the infil at .3 layer height and the perimeters at .1 or .05? Any thoughts or experience in setting up dual extruders to do this would be great!
jheikkila54
Re: Printing with different nozzle sizes
I tried making 3 processes:
Process 1 - print brim and first layer at layer height of .3 with the .8 nozzle and end at layer height of .3
Process 2 - print the perimeter, top, and bottom layers at 3 loops, 0% infill, and to start at layer height of .3, printing at .1 layer res with .3 nozzle
Process 3 - print the perimeter, top, and bottom layers at 0 loops, 15% infill, and to start at layer height of .3, printing at .4 layer res with .8 nozzle
Doing this crashes S3D. Any thoughts or other ideas.
If you are using auto extrusion width, than it's as easy as changing the nozzle diameter on the Extruders tab for each different extruder. If you're using manual extrusion widths, then you'll have to change that value manually.
As for printing at different layer heights, that is also possible. For example, you could print 3 outline perimeters at 0.1mm layer heights and then one single thick infill layer at 0.3mm. To do this, set your layer height to 0.1mm and then click on the Infill tab and change it to say "Print sparse infill every 3 layers". That way it prints 3 perimeter layers for each single infill layer. The software takes care of the rest :D
jheikkila54
Excellent, Thank you so much! this changed the print time of a 26 hour print to 17 hours!
Rebekah_harper
I run a 0.2mm nozzle with a 0.4mm nozzle.
I tend to use one process printing at a layer height of 0.1, perimeter with 0.2 and then the rest with the 0.4 printing every 2 layers.
