dsegel wrote:Hmmm...I get what you're saying, but I still think it's wrong. Infill density should be calculated based on area, not weight of the plastic.
Grid and honeycomb should always print every infill angle on each layer. (there should only be one for honeycomb and two for grid)
If you specify more than one angle and DONT have that box checked, then your back to the same problem with the rectilinear infill. (only intersection points are connected in the Z direction)
your pictures don't appear to use more than one angle, so I would agree--this is a bug.
to me, the "print every infill angle on each layer" is a way to get simplify to print a grid pattern (or other pattern using several angles) using rectilinear infill. It would be easy to overfill at the intersection points, but you could do some pretty interesting patterns this way.
