2Mylent
Prusa i3 Rework - choice of pre-configured printer?
Hello,
Currently I use a Printrbot Simple Metal. I'll add a new printer that I built on a Prusa i3 Rework base with some modifications as adding heating bed 200x300mm and sensitive sensor (z-probe).
To install this printer with S3D v3.0, which is the best choice of pre-configured printer?
- Bq Prusa i3 Hephestos (no heated bed and bed 200x200)
- Prusa Mendel (???)
- Other
Thank you for your help.
Simplify 3D // Printrbot Simple Metal + Heated Bed + E3D v6 // Prusa i3 base Rework 1.5 + Heated Bed 200x300 + E3D v6
TopJimmyCooks
Re: Prusa i3 Rework - choice of pre-configured printer?
For my I3v variant (MakerFarm I3V - Clough42 dual extruder/RRD hexagons, 200x200x200, heated bed) I just went in to the machine settings and made my own profile. the issue with RepRap equipment is there are just so many variations in size, thread pitch, extrusion, etc, It's not like a wanhao duplicator where they're all basically the same equipment/spec's for a given model.
Also, check the forums for mentions of your printer and see if someone else has a profile they can share that you can import and start from.
Makerfarm 8" I3v | Clough42 Itty Bitty Double Extruder | RRD Hexagons | Now with More Simplify3D
2Mylent
Thank you ;)
I chose "Other" and made the bases of the parameters of Prusa i3 Rewoek, bq Hephestos and Ooznest :P
