Corkscrew printing mode would be best, the extruder gradually increases in Z axis. This is sometimes referred to as vase mode.
If you are actually needing infill, you could turn on wiping, and perform retraction during wipe movement. You could also need coasting, depends on when the zits are being formed. Coasting will help if the extruder is extruding too much due to pressure built up in the extruder assembly. Wiping helps in a similar way but fully extrudes the line and then drags along the perimeter to catch any excess on the inner perimeter instead of leaving the deposits on the outer surface. Turning on retrcat while wiping will make this even more powerful as it will perform a retraction of the filament and wipe the excess AT THE SAME TIME!
Setting Locations:
