Printer
Davinci XYZ 1.0a with Repetier .92
225 Extruder
110 Bed
Printed with ABS
Model
http://puu.sh/iJxGO/27cc0d738b.stl
Exactly the same, it looks like the entire print started smaller on those layers and then progressively gets larger with the height. I did print with a brim/skirt and it appears that the print was offset by the size of the skirt (5 wide, 5 high, .80 from the object). I am going to turn the skirt off tonight to see if that changes it.DarthRevan wrote:what do the other corners look like?
I don't see anything wrong with the gcode. Have you changed any of the settings in your firmware? Do all of your prints grow in the x and y axis?
I didn't change any settings beyond the baudrate to try to correct the disconnect issue I am having. I forgot to mention this is a Mac OS Simplify3d install as well. All of the prints on this printer appear to be doing the same growing print. I printed a couple of parts with a smaller skirt (2 x 2) and it was smaller, but still present in the part.DarthRevan wrote:I don't see anything wrong with the gcode. Have you changed any of the settings in your firmware? Do all of your prints grow in the x and y axis?
