falstaffpac wrote:I would be interested to know if anyone figures out how to size and position the STL file relative to the print bed. I spent several hours attempting to do this yesterday. I also tried sizing my STL relative to the LulzBot_TAZ3.stl file with no luck. It seems pretty straight forward to place the STL image below the print bed, but I would like to create one which surrounds it.
The file for the bed STL is stored in the folder below. You will need to enable viewing of hidden folders in the control panel to get to this filepath.
C:\Users\**USERNAME**\AppData\Local\Simplify3D\S3D-Software
The Bed STL isn't translated or rotated at all. Therefore to get your STL ready for import you would need to import it into Simplify3D, and move it around and then go to File-->Export STL when you have it translated/rotated corrected and save as a new STL.
From there, you can simply replace the LulzBot Taz STL in your Appdata\Local\Simplify3D\S3D-Software filepath. It's easiest if you keep the same name, that way you don't have to export your FFF Profile and change the data, then reimport it.
