JoeJ wrote:You're using far too large of a support pillar size for a part that small. That's why you're seeing some pieces that are outside the part.
This ring is only about 6mm wide. You are using a support pillar size of 4mm which is far too big for a part that small. Change it to 1mm and it works perfectly.
In general, you want to use smaller support pillar sizes for small models with small features. Larger models with big features can use larger support pillar resolutions.
Thanks for the feedback. I've never done anything but the default supports.
I can see how using a smaller support might help. However, this is not a small part and I've never had a problem with supports when I've printed with single extrusion. It seems that slicing with smaller supports does help prevent the weird outside useless supports from being generated but I'm still seeing the middle section sliced at 100% infill for some weird reason.
