My last print almost went well except a small error at the tip, so yet another question now comes up. (Using Makergear M2, MG BLK ABS 1.75mm)
My parts are typically printing great, all the way until the extruder has to work on very small layers tapering to a point, that is. I haven't actually had a part with this type of feature come up until now. In my last thread, for example I was printing a replica rifle round. The bullet is fine, except the last 3-4mm at the tip, it looks like a swirly ice-cream cone. Photo is below. I am using 0.160mm layer height which is "my standard" for fine detail.
I'm thinking that I need to set the travel speed higher where this localized heating begins happening, since it is staying in the same area too long it would appear, and melting the detail away. I was thinking at layer #245, right below where this problem begins, change to an FFF setting with 2 or 3x the printing speed to finish the part.
Also, check out the photo of my layer start points. The retract and extra start distance. I had bumped retract up to 3.00mm. I believe the retract is causing this dent along that line. Would 2.20mm retract be more appropriate a setting, or could this have to do with extra restart distance more so? Attached FFF.
Suggestions?
Part rendering:
Finished tip:
Retract and Extra Restart Distance line (set at 3.00mm and 0.05mm, also the retract lift is set at 0.10mm):
