I've used brim on many projects where I split the part in two to prevent using supports, and then bond the two halves together. Brim works fine for that as the part is held to the print bed and the bottom bonding surfaces are glass smooth. I can't easily do the same with only the raft available. In your latest release you indicate that Creator supports brims, but how does one generate a proper brim. I've searched the subject of brim in the Quick Start guide and on this forum, but there aren't any instructions on how to generate a brim.
Thanks,
Walt
