evertonp
[ADDED] Material cost > 99.99
Dears,
I think this should be easy one to fix, I saw the material cost is limited to 99.99 but in some countries, the currenty makes it above that per kg.
Mine cost average of 110,00 ABS depending on the material. For PLA is higher.. so please fix it..
Thanks!!
Everton
Patola
Re: [Feature request] Material cost > 99.99
I second that request, maybe because I am from the very same country? :D And after all, it might not be something you need due to the price - maybe you are selling 3D prints (which is my case). And in this case, you might charge, say, 5 times the price of the filament, so even if you get a filament that costs as low as $30, you want to calculate as if it costed $150.
vOidward
Faberdashery 1.75 filament filament ends up being north of 100 per KG when you work out costs.
Not a huge deal, can just do 1/10 and multiply, but it is a little odd that it's capped at 2 digits.
Alex Borro
I second that.
I see no purpose on limiting the cost to 2 digits; I guess the S3D is not only meant to US market.
Trax
stupid question i know, but where can i find the setting for the material cost?
KeyboardWarrior
Trax wrote:stupid question i know, but where can i find the setting for the material cost?
Click Edit Process Settings, then it's under the Other tab
The material cost now supports up to 5 digits to support more worldwide currencies
