kyphur
[ADDED] Scaling is reset after reloading
I noticed that when I print something I can change the scale. Upon reloading the file or even the factory file the scale resets to 1. It would be nice to be able to see the original scale value also. I just spent 30+ hours printing multiple pieces to come back in for filament of a different color only to have the scaled version set at 1. Now I don't know what my original scale was to match up the parts for assembly. :(
sully777
Re: Scaling options
I will second this. Need a way to scale by percentage also, for printing Raptor Prosthetic hands and other stuff.
Zekeman
Re: Scaling options
Great suggestions and also a +1 on the scaling by percentage.
Re: Scaling options
Guys, s3d does scale by %. Just double click the model. The scale boxes are right there. If you wanted to double the model size then enter 2 which is 200%. If you want to scale up 25% then enter 1.25
Re: Scaling options
This issue has been fixed in version 3.0. If you change the scale and then close and reopen the software, the scale correctly shows the change you made and does not reset back to 100%.
